always have had the problem. have changed client, server, router, and issue stays. making me think might be from remotly itself.
run in home wifi >500mbps, RTT < 5 ms, never above 20ms. once in a few minutes, get a freezing with the bad network symbol on for 0.5-3, typically 1-2 seconds, and the connection completely freezes (not pixelation). quite annoying.
did concurrent network throughput monitoring between the same client/server, during the freezing, the throughput did not drop nor RTT spiked.
run parsec and anyviewer (btw, it now supports hardware encoding) from the same client/server, never experienced any noticeable freezing.
again, it might be unique to my environment...
