Android can't use p2p to connect to computer using remotly
Hi ao55jr. Sorry for the late reply. P2P can be blocked in many cases either by the ISP or by router. Are you sure your phone network provides allows P2P connections? If yes then you may need to port forward P2P on your home router (maybe you have more than one router).
