Can't connect without user login. boot process not running
hhspiny
v1.26
Uninstall previous remotly, reboot, install remotly in administrator account, login to remotly account, set "start with windows" off then turn on again, reboot.
Without any user login, "Computer/Administrator" appears offline. requires login to administrator account on server first to be able to connection. if logout of administrator, the "Computer/Administrator" becomes offline again.
It appears that the "boot process" is not running. I think I have had this problem since a couple of versions back. this also affects normal user account on activities associated with UAC.
Hi hhspiny,
Sorry for the late response to this thread. Are you sure the remotly_boot_svc.exe appears/disappears in task manager details/process list when you turn the "Start with Windows" option on and off?
