Can you check if this ever happens without administrator rights? You need to close Remotly and start Remotly.exe from the installation folder.
Usually this kind of problems are related with low level high performance screen capture. When running without this you will still get good performance and will be able to check if this problem persists.
Can you let me know what GPU are you using and what Windows version (extact like Windows 11 24H2).
Thanks!
