Mac OS Help
araddepalli31
Hi Remotly Team,
I'm reaching out about potential Mac M2 support for your platform. I'm specifically interested in game controller compatibility and whether your app can simplify the connection process compared to Windows, which requires ViGemBus drivers. Would you be able to support multiple gamepad controllers on Mac? Additionally, I'm curious if there might be a future option to connect a Nintendo Switch to a Mac Mini via HDMI, with the ability to run the app in the background.
Hi araddepalli31,
Development of Remotly PC 1.x for Windows is almost completed.
There is one last big feature that will be added. It allows multiple user connection to one host/server.
This feature will allow up to 4 players with 4 remote gamepads to play together on one host PC.
MacOS and iOS development is underway and is at the highest priority for us.
We will do our best to make these apps, as well as remote gamepads, easy to use and straightforward.
Clients for consoles like Nintendo Switch 1 and 2 as well as PS5 are also planned.
