P2P connection
LIC
Hello, how to setup P2P connection? , in connection says P2P but connect anywere traffc count, i try to forward port udp and tcp but no traffic come though it.
Hi LIC,
If you are connecting from an external network then you might need to set port-forwarding (this may sometimes not be possible if the operator blocks specific, non-standard ports).
Please let me know what is your connection setup (is the external network LTE etc.)
