We are very sorry for any problems that might have occurred for you during the past 2 days of using Remotly.
The most serious problem is that some logged in unattended remote devices might show error during remote connection (both using P2P and Connect Anywhere or custom relay).
The only fix in this situation is to either restart Remotly host or reset network connection on this host (unfortunately remote reboot also does not work for such remote hosts).
Problem should not occur anymore as it has been fixed in the data center.
Please forgive us for this inconvenience
