This update contains critical fixes for the following problems:
- Added support for up to 4 remote gamepads using Vigem driver (+ additional Bluetooth keyboard and mouse allowing to remotly use up to 6 devices). The on-screen gamepad layout for Android acts like a real physical gamepad so it occupies one slot and 3 gamepads can be used in this case (giving a total of 4)
- Adds support for GUIDE key on gamepads (useful for starting Steam Big Picture remotely)
- Added mouse capture support for Android 8.0+ (works in game mode only, please switch to game layout mode). This is an important feature that allows remote mouse to control in-game camera movement just like on the PC
- Fixed numeric keypad not working (on PC and Android when a standard PC keyboard is connected)
- Many important fixes for keyboard input
- Countless other fixes...
PLEASE NOTE that we have done our best to make this update compatible with the previous version but some problems might occur so it is HIGHLY recommended to install the newest version on all devices.
The Android version v1.30 will be available soon on Google Play Store after validation (for now you can use the APK from the download section)
Summarizing. With this release it is now possible to create a remote PC from an Android tablet with mouse and keyboard emulating everything that can be done on the remote PC locally. It is also possible to create a remote gaming console with 4 gamepads
