Hmm. Maybe this problem is related with these Virtual adapters. Is it possible to disable them for test an leave only one physical?
It would make the investigation easier if you could insert a screen form wireshark when the connection works via VPN. We could see what IPs are used and ports.
Hi vamp, can you set the inbound port (serwer port is inbound and outbound is for PC client) to RDP port 3389
So the PC and Android clients behave different?
I'm confused. Do you see UDP packets in wireshark after connecting using VPN?
Hmmm maybe it connects so long using VPN that is switches to connect anywhere but not always?
There is a 10sec timeout before the switch happens. Maybe this timeout is too short?
yes, i confirm it.Can you please confirm that the wireshart screen was done in the same scenario whene Direct Connection is switching to cloud?
BTW. We will speed up direct connection from PC and increase the timeout. If the wireshark screen shows truth then it worked but does not work always.
Ok, so we now know that it worked at that time and it was a direct connection. We will increase the timeout and speed up the PC client connection time to be as fast as the Android version. Soon we will also add simultaneous connection to many PCs at the same time from one PC (sessions) and a special mosaic mode for monitoring up to 16 PCs without connecting to them (refreshed every 15sec).
